Method AddAnnotPolyline always fails 11 years 3 weeks ago #9194
  • mzuber23
  • mzuber23's Avatar Topic Author
Using even the most simple example, if I create an empty page, and then try to add a polyline annotation to it, the method returns false. For example, if I do the following, AddAnnotPolyline returns false:
            Path path = new Path();
            path.MoveTo(10, 10);
            path.LineTo(20, 12);
            path.CurveTo(30, 20, 20, 30, -10, 50);
            path.ClosePath();
            if (!page.AddAnnotPolyline(path, 0, 0, 0xFF000000, 0, 4)) {
                       // Handle error.
AddAnnotInk does not exhibit this problem. I am using the latest beta version, which is 3.5 beta 8. Is this a known issue? As a side note, is it possible to add a quadTo function to the Path class? It's really inconvenient to have to use a cubic bezier for the calculations I'm doing.
Mike
Method AddAnnotPolyline always fails 11 years 3 weeks ago #9207
we will check it and get back to you as soon as possible..
Method AddAnnotPolyline always fails 11 years 2 weeks ago #9228
it always failed, to add closed path to PolyLine.
for closed path, using Polygon instead.
Method AddAnnotPolyline always fails 11 years 2 weeks ago #9230
  • mzuber23
I was using a much more complex example in my code, and I think my PDF coordinates were incorrect. Regardless of what happened, I no longer seem to have the error with adding the polyline annotation, so I apologize for the confusion.
Mike
Last edit: by mzuber23.
