Calculating rect size for AddAnnotEditbox 10 years 11 months ago #9376
  • artkön
  • artkön's Avatar Topic Author
Hi, I would like to display a text in an editbox annotation as one-liner.
How can I calculate the proper bounding box for the method AddAnnotEditbox?
Is there any function for calculating text sizes in PDF coordinate system?
Last edit: by artkön.
Calculating rect size for AddAnnotEditbox 10 years 11 months ago #9392
sorry for the delay, there are no direct API to do this.
I suggest you to look at Android method getTextBounds and to use this to handle the rect of the AddAnnotEditbox method.
