Another page starts appearing during zoom at side. 10 years 11 months ago #9490
  • deepaksharma
  • deepaksharma's Avatar Topic Author
I am currently using PDFViewDual with single page to load pdf. When I zoom at side of page(left/right), some part of next page also starts appearing. Please help me to prevent another page to display and only display the current page.
Another page starts appearing during zoom at side. 10 years 11 months ago #9491
yes, this is the standard behaviour of the library.
Another page starts appearing during zoom at side. 10 years 10 months ago #9564
  • fullmers
  • fullmers's Avatar
Hi Davide,
Is there a way to modify this behaviour?
Last edit: by fullmers.
Another page starts appearing during zoom at side. 10 years 10 months ago #9565
you can implement it by yourself.
The best way to achieve this is using a ViewPager and in each page open a page of the pdf, but you have to check all the gestures (tap, fling, drag..) and handle them correctly.
A sort of workaround could be to follow this knowledge base article, that stops the swipe when a page is zoomed.
www.radaeepdf.com/support/knowledge-base...component&kbartid=15
Another page starts appearing during zoom at side. 10 years 10 months ago #9566
If you want a sample project, you can open a ticket, address it as a bug and in the text refer to this post in the forum.
