Which class to use for display? 10 years 7 months ago #9922
  • micrad
  • micrad's Avatar Topic Author
Which class should I use as the base of displaying a PDF inside a fragment?
I found, there are a couple of candidates and the JavaDocs are completely unclear which class does exactly what?
PDFView, PDFViewCurl, PDFLayoutView or PDFGridView?
Which class to use for display? 10 years 7 months ago #9925
PDFView is base class ith empty implement.
PDFViewCurl is derived class from PDFView.
these 2 classes used in Module PDFReader
PDFLayoutView used in Module RDPDFReader, which support very large zoom scales.
PDFGridView display first page of all pdf files under a path.
Which class to use for display? 10 years 7 months ago #9933
  • micrad
I see. I studied the PDFReaderAct in the demo.
So, I assume, to use the com.radaee.reader.PDFReader class, I need to import it as a module in Android Studio, the same way I did with ViewLib.
However, when I do this:
I change PDFReader Module to be a library instead of application, fix an issue with the manifest merger change the launch configuration to use my app's main activity, I am getting DUPLICATE app icons!
Please advice, how to fix that.
Which class to use for display? 10 years 7 months ago #9934
  • micrad
Fixed by removing
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
from PDFReader Manifest
