add EditText and check box at pdf 10 years 5 months ago #10319
  • ankur123987
Hello Davide
I am using the RDPDFReader module and PDFLayoutListener,PDFView.PDFViewListener interface for implementation. the methods of PDFLayoutListener,PDFView.PDFViewListener is never called in my activity please help
add EditText and check box at pdf 10 years 5 months ago #10320
Hi.
in RDPDFReader module the OnPDFSingleTapped method is divided into:
  • OnPDFAnnotTapped if you tap an annot
  • OnPDFBlankTapped if you tap a blank zone.
So you can place you method in OnPDFBlankTapped
add EditText and check box at pdf 10 years 5 months ago #10323
  • ankur123987
Thanks Davide for reply .
the problem with onPDFBlankTapped method are following .
1 this method does not contain any parameter . i want add text at touch position of pdf at tap location so i need the coordinates of touch event so that i can add text .
2 onPDFBLankTapped method works at blank pdf page location its does not work where image text or any content is printed so this method is useless .
please tell us any example or way to execute the add text at touch location
Thank you
Last edit: by ankur123987.
add EditText and check box at pdf 10 years 5 months ago #10324
you can edit PDFLayoutListener like this:
public void OnPDFBlankTapped(float x, float y);
and pass the coordinates in onSingleTapUp method like that:
m_listener.OnPDFBlankTapped(e.getX(), e.getY());
So you will have the x and y to addText.
