add EditText and check box at pdf 10 years 6 months ago #10035
  • ankur123987
Hi radaeepdf team.
How can i add the editview and check box at pdf . using radaeepdf
Last edit: by ankur123987.
add EditText and check box at pdf 10 years 6 months ago #10080
you can add edit box using AddAnnotEditbox
For more info check www.radaeepdf.com/documentation/javadocs...html#AddAnnotEditbox(float[], int, float, int, float, int)
The feature to add check box is not yet available.
We will tell you when it will be ready
add EditText and check box at pdf 10 years 6 months ago #10085
  • ankur123987
but how to add the this annotation how can i add into my pdf at on touch position ? do you have any demo or source code for it?
add EditText and check box at pdf 10 years 6 months ago #10095
  • ankur123987
please reply me asasp
add EditText and check box at pdf 10 years 6 months ago #10097
you have to pass OnTouch coordinates to AddAnnotEditbox method.
I suggest you to look at onTouchNote method of PDFReader class or at the other "addAnnot" methods usage.
add EditText and check box at pdf 10 years 6 months ago #10102
  • ankur123987
I checked pdfreader class . where to get m_view object and ontouchevent implement in my own actvity . Do you have any source code for it?
please provide any simple code for add the text
thanks
