How to use hyperlinks with CurlView 10 years 6 months ago #10078
  • kpurushottam
  • kpurushottam's Avatar Topic Author
I am trying to view the pdf in a curl page swipe effect, but in curl effect, links not works
How to use hyperlinks with CurlView 10 years 6 months ago #10079
I suggest you to look at this article : www.radaeepdf.com/support/knowledge-base...component&kbartid=21
How to use hyperlinks with CurlView 9 years 10 months ago #11196
  • olik79
  • olik79's Avatar
I'm facing the exact same problem, links don't work within PDFViewCurl and you can't zoom into the pdf file. Now I've taken a look at the posted PDFViewCurl class from the link. It contains fields that don't exist anywhere, not in PDFViewDual and not in PDFView. Not even as private fields that I could change into protected. Is this code for a previous version of the framework?
Thanks in advance for any helpful advice :).
How to use hyperlinks with CurlView 9 years 10 months ago #11203
This class represents a guide that can be used to achieve the required effect.
It can be enhanced based on your needs, and the
To make it work, the article has been modified please recheck
