downloaded demo of radaeepdf is not working 10 years 6 months ago #10111
  • ankur123987
Hi Radaeepdf team,
i am getting very strange experience with PDFReader demo. i test the demo 2 days back . it was working fine. now i am using same apk file and all features are not working (Ink,rect,oval,note,line .. etc) please help as it basic presentation by radaeepdf for integration any feature .
please fix this issue as soon as possible or please suggest what should i do ? i tried to integrated the latest android studion3.6.1 version but same error
Last edit: by ankur123987.
downloaded demo of radaeepdf is not working 10 years 6 months ago #10112
seems, it open PDF files in readonly way.
downloaded demo of radaeepdf is not working 10 years 6 months ago #10113
  • ankur123987
its showing the ink, rect,oval,note,line etc are displaying but not woking . so how can i resolve this issue . i use same pdf files previously . these function were working on that files . so how can i make that files editable
thanks
downloaded demo of radaeepdf is not working 10 years 6 months ago #10114
if u use Document.OpenStream() means open from assets or http link directly, it must be readonly
if u use Document.Open( path ), using following codes to check writeable:
        File file = new File("/sdcard/test.pdf");
        boolean writeable  = file.canWrite();
others: a PDF file open twice (without closed), the first time u opened is writeable, and second time, it shall be readonly.
downloaded demo of radaeepdf is not working 10 years 6 months ago #10121
  • ankur123987
i am using PDFReader demo. this demo have grid view to open the pdf file.i think you are confused with RDPDFreader demo . i can open the file via using grid view . i tried with tap on edit button but no luck .
hope you got me
thanks
