OpenStream Problem 10 years 5 months ago #10167
  • aminnouri
  • aminnouri's Avatar Topic Author
i wanna open stream a linearized byte in range link with open stream method , when i test it in android 4.x it works perfect but when i test in android 6 and 5 it does not show any thing and log st like this:
D/Total Size:: 3942405
W/art: Suspending all threads took: 9.954ms
and repeat second line
plz help me its urgent
OpenStream Problem 10 years 5 months ago #10180
can you reproduce it with the last version of the library?
Can you reproduce it with smaller pdfs? Can you please send us the pdf link to test it?
OpenStream Problem 10 years 5 months ago #10186
  • aminnouri
i test new library no difference ,
when i create an app just stream a pdf its work but when i transfer this code to my main project its freeze on hand_val = openStream(stream, password); and dont get any log and after a while said Suspending all threads took: 6.218ms ,
its my link : 79.143.84.146/webapi/magazine/bytesinrange/67
i attach my sample app too. open open login with This email address is being protected from spambots. You need JavaScript enabled to view it. and pass:qweqwe after that select one of image and then select button with title "خواندن نشریه" after that start to stream.
plz answer fast
thanks
OpenStream Problem 10 years 5 months ago #10194
  • aminnouri
I solve the problem.
the problem is is set locale:
Locale locale = new Locale("fa");
Locale.setDefault(locale);
when i set locale to 'fa' its can not get any thing from stream.
i hope you solve this problem in next version.
thanks
