How to load gif files from sd card to PDF? 10 years 5 months ago #10207
gif are not supported, but you can convert your gif to jpeg or save it into a bmp, remember that bmp are not compressed so when you add them to your pdf file, it may became bigger.
I suggest you to look at AddAnnotBitmap and this article : www.radaeepdf.com/support/knowledge-base...component&kbartid=27
