Out of memory using viewpager 10 years 5 months ago #10212
  • vitorpradoveri
  • vitorpradoveri's Avatar Topic Author
I've bought the license to use Radaee in Android app.
I need to setup the pdf using a ViewPager, I found the example in RDPDFReader..
But the PDFViewPager throws an out of memory exception after some pages.
I was looking into PDFViewPager implementation and I found an array with the pages, and it's never released by GC.
maybe this is the problem.. I really don't know how can i solve this. I need to implement my own viewpager with my own adapter?
Out of memory using viewpager 10 years 5 months ago #10217
can you reproduce this issue with all the pdfs? Can you please send us one of your pdfs to test it..
I invite you to open a new ticket bout that issue here: www.radaeepdf.com/support/tickets
Out of memory using viewpager 10 years 4 months ago #10364
  • alolip
  • alolip's Avatar
Is there a solution for this issue?
I'm having it too,
seems like objects are never released
Out of memory using viewpager 10 years 4 months ago #10366
hi, u maybe using old version.
plz check codes for PDFViewPager class, there are implment codes for PagerAdapter:
    private class PDFPageAdapter extends PagerAdapter
        private Document m_doc;
        public PDFPageAdapter(Context ctx, Document doc)
            m_thread = new VThread(m_hand_ui);
            m_thread.start();
            m_thread_cache = new VThread(m_hand_ui);
            m_thread_cache.start();
            int cnt = doc.GetPageCount();
            m_pages = new PDFPageView[cnt];
            m_doc = doc;
            int cur;
            for(cur = 0; cur < cnt; cur++)
                m_pages[cur] = new PDFPageView(ctx);
                //m_pages[cur].vOpen(m_thread, m_thread_cache, doc, cur, m_fit_type);
        public java.lang.Object instantiateItem(android.view.ViewGroup container, int position)
            if(!m_pages[position].vIsOpened())//lazy loading.
                m_pages[position].vOpen(m_thread, m_thread_cache, m_doc, position, m_fit_type);
            container.addView(m_pages[position]);
            return m_pages[position];
        public int getCount()
            return m_pages.length;
        public void destroyItem(ViewGroup container, int position, Object object)
            m_pages[position].vFreeCache();
            container.removeView(m_pages[position]);
        public boolean isViewFromObject(View view, Object o)
            return view == o;
        public CharSequence getPageTitle(int position)
            return "Page:" + position;
callback method destroyItem shall free memories.
Out of memory using viewpager 10 years 4 months ago #10367
  • alolip
  • alolip's Avatar
I'm having it too,
Out of memory using viewpager 10 years 2 months ago #10563
  • thiagopelikan
  • thiagopelikan's Avatar
Same here!
