add EditText and check box at pdf 10 years 5 months ago #10224
  • ankur123987
thanks david for write the separate function that function is not worked for me as i use PDFLayoutView and VPage class however i modified your code now worked for me i have other query i want to add text on touch event .
similiar as in demo of adding "note" . in currently method i have to pass static parameter for particular area . i want it dynamically
please help one more query invalidate() is not recoznized in activity class so its take some scrolling of pdf for refresh the page . what would solution of it
thanks you
Last edit: by ankur123987.
add EditText and check box at pdf 10 years 5 months ago #10225
you can place addTextBox in the OnPDFSingleTapped method, pass x and y and change the rect parameters as you want..
To refresh the view please try with :
m_reader.invalidate();
add EditText and check box at pdf 10 years 5 months ago #10226
  • ankur123987
hello Davide ,
i check the OnPDFSingleTapped method its never called . i implement the PDFView.PDFViewListener, please help
add EditText and check box at pdf 10 years 5 months ago #10229
add EditText and check box at pdf 10 years 5 months ago #10232
  • ankur123987
Hi davide,
I checked the knowledge base post but there is no OnPDFSingleTapped method in PDFReaderListener and PDFLayoutListener interface.. i am implementing PDFView.PDFViewListener . but OnPDFSingleTapped is never called
please help
add EditText and check box at pdf 10 years 5 months ago #10318
  • gregh530
  • gregh530's Avatar
Do you have code sample for this functionality? Thank in advance, Greg
