Android background color white during rendering 9 years 11 months ago #10239
  • lucianoEpress
  • lucianoEpress's Avatar Topic Author
HI Radaeepdf team,
i'm using the sdk android and during pdf rendering,
I notice a white background on the tiles drawing until the rendering is complete.
Is it possible to set a trasparent background on the tile ?
Regards
Android background color white during rendering 9 years 11 months ago #10249
can you reproduce this with all the pdfs? Can you please send us one of these pdfs to test it?
Can you please tell us the steps to reproduce that issue?
Android background color white during rendering 9 years 11 months ago #10253
  • lucianoEpress
I attach a pdf file that I am using.
the code i wrote is (in acticity onResume())
you have to copy 01.pdf in download device directory.
you can see the same problem with radaeePdfViewer in Play Store.
thanks
protected void onResume() {
rel1 = (RelativeLayout) findViewById(R.id.relativeLayoutRoot);
Global.Init(this);
Global.render_mode = 1;
Global.zoomLevel = 3;
mTest_RADAEEPDF3 = new Test_RADAEEPDF3();
mRdee_View = mTest_RADAEEPDF3.Get_mview();
rel1.addView(mRdee_View);
mRdee_View.bringToFront();
mTest_RADAEEPDF3.OpenDocument();
// Private class to use PDFLayoutView
private class Test_RADAEEPDF3 implements PDFLayoutView.PDFLayoutListener {
PDFLayoutView m_view;
Document m_doc;
public Test_RADAEEPDF3() {
m_view = new PDFLayoutView(mContext);
m_doc = new Document();
public void OpenDocument(int iInd) {
String sFileNameInput = Environment.getExternalStorageDirectory().toString() + "/download/" +
"01.pdf";
int ret = m_doc.Open(sFileNameInput, "");
if (ret == 0) {
m_view.PDFOpen(m_doc, this);
//I need setview = 4
m_view.PDFSetView(4);
public PDFLayoutView Get_mview() {
return m_view;
public void Close_mview() {
if(m_view != null) m_view.PDFClose();
if(m_doc != null) m_doc.Close();
public void OnPDFOpenURI(String uri) {
public void OnPDFPageModified(int pageno) {
public void OnPDFPageChanged(int pageno){
public void OnPDFAnnotTapped(VPage vpage, Page.Annotation annot){
public void OnPDFBlankTapped(){
public void OnPDFSelectEnd(String text){
public void OnPDFOpenJS(String js){
public void OnPDFOpenMovie(String path){
public void OnPDFOpenSound(int[] paras, String path){
public void OnPDFOpenAttachment(String path){
public void OnPDFOpen3D(String path){
Android background color white during rendering 9 years 11 months ago #10258
can you reproduce this issue with the demo project?
Please open a ticket here www.radaeepdf.com/support/tickets and attach the pdf to the ticket.
Android background color white during rendering 9 years 11 months ago #10264
  • lucianoEpress
Done,
thanks
Regards
Android background color white during rendering 9 years 11 months ago #10307
  • lucianoEpress
HI Radaeepdf team,
I would like to correct my question from
"Is it possible to set a trasparent background on the tile ?"
to
"Is it possible to set a background on the tile like pdf backgroundcolor?"
Regards
