Pdf is not fit to height on certain devices. 10 years 5 months ago #10270
with PdfLayoutView you should use
m_view.PDFSetView(int def_view);
to change view.
Pdf is not fit to height on certain devices. 10 years 5 months ago #10292
Was you adding the link of uploaded attachment to your post body?
May you try again?
Pdf is not fit to height on certain devices. 10 years 5 months ago #10298
you can't fit your pdf both in height and width, because the ratio between height and width of the pdf are different from the ratio of the screen dimensions.
I suggest you to center the pdf vertically on the reader.
Pdf is not fit to height on certain devices. 10 years 5 months ago #10310
this is the documentation about layout parameters
     * set layout parameters.
     * @param verts applied duals flag for vertical screen
     * @param horzs applied duals flag for landscape screen<br/>
     * Element which set to true mean this cell treat as dual page, otherwise treat as single page.<br/>
     * For example, book has a cover(first page treat as single) just codes:<br/>
     * verts = null;<br/>
     * horzs = new boolean[1];<br/>
     * horzs[1] = false;<br/>
     * Pages, those out of array bound:<br/>
     * in vertical screen: treat as single page(false).<br/>
     * in landscape screen: treat as dual page(true).<br/>
To center the pdf vertically you have to set the last parameter (page_align_top ) to false.
