Project Examle for pdf View in android 10 years 4 months ago #10399
  • asendead21
  • asendead21's Avatar Topic Author
hi everyone, I want to make pdf reader using radaee pdf... can u give me some example source code or project to set pdf view from assests ? I've import all libs from radaee but I'm confused to make simple pdf view... thanks for your reply...
Project Examle for pdf View in android 10 years 4 months ago #10400
this guide will help you to import radaee reader to your own project : www.radaeepdf.com/support/knowledge-base...component&kbartid=41
In module RDPDFReader you will find some example of how to open pdf from asset in PDFViewAct:
if( pdf_asset != null && pdf_asset != "" )
        		m_asset_stream = new PDFAssetStream();
        		m_asset_stream.open(getAssets(), pdf_asset);
        		m_doc = new Document();
        		int ret = m_doc.OpenStream(m_asset_stream, pdf_pswd);
        		ProcessOpenResult(ret);
