Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10530
can you please send us your code, so we can check it?
If you want, you can send it privately here : www.radaeepdf.com/support/tickets?view=ticket&layout=open
The following user(s) said Thank You: sharikakanakam
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10531
  • sharikakanakam
  • sharikakanakam's Avatar Topic Author
I have attached my classes in a ticket: ticketid=969.
Last edit: by sharikakanakam.
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10532
  • sharikakanakam
Did you get the three files that I sent you?
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10536
  • sharikakanakam
I got this working! There was an issue with the pdf file that I was using. When I used another file it worked! Thanks for the support!
