Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10444
  • sharikakanakam
  • sharikakanakam's Avatar Topic Author
Sure. Can I send it privately?
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10445
Yes, please open a private ticket here : www.radaeepdf.com/support/tickets and attach your pdf.
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10446
  • sharikakanakam
This is the ticket with th pdf attached :
www.radaeepdf.com/support/tickets?view=t...ut=view&ticketid=943
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10447
I have checked your pdf and in the 2 fields next to the word "Sign" there are no annotations!
I think you have to put a sinature annot into these boxes, because now are empty.
Then you have to check the type of annot using the methods I suggested you before.
Something like that :
if(m_annot != null && m_annot.GetType() == 20 && m_annot.GetFieldType() == 4){
	//handle annot
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10452
  • sharikakanakam
Thanks again! I managed to add a signature annotation and I was able to detect this field in the app. So my idea is to turn on the ink feature programmatically when a 'signature' field is detected. One more question on this, how can I fetch this signature object(image object) after I have signed into this field? Do you have a sample code anywhere for that?
Extracting fields and Checkbox Tick Mark 10 years 3 months ago #10453
I suggest you to save it into a bitmap and then add it to the rect coordinates of the signature field using this method:
page.AddAnnotBitmap(Bitmap bitmap, boolean has_alpha, float[] rect);
For more info check this: www.radaeepdf.com/documentation/javadocs...map-boolean-float:A-
