Double tap Zoom 10 years 3 months ago #10477
  • digitalpages
  • digitalpages's Avatar Topic Author
I need create a feature using double tap for enable zoom, but I can't do the layout goes to the position tapped.
Follow my code:
public void doZoom(int x, int y) {
final float scale = m_layout.vGetZoom();
float zoomTo = scale + 1;
if (scale >= maxZoom) {
zoomTo = 1.0f;
m_layout.vZoomStart();
final PDFPos pdfPos = PDFGetPos(x, y);
m_layout.vZoomSet(x, y, pdfPos, zoomTo);
m_layout.vZoomConfirmed();
Double tap Zoom 10 years 3 months ago #10479
if you want a doubleZoom In/Out you only have to add the following line at the end of OnPDFDoubleTapped method of PDFReader class before the return statement:
Global.zoomStep *= -1;
Maybe this will help you : www.radaeepdf.com/forum/Android-developm...et?limitstart=0#9795
If you want a different behaviour please better explain your needs..
Double tap Zoom 10 years 3 months ago #10489
  • digitalpages
HI,
I'm using PDFLayoutView and this don't have a onPDFDoubleTapped method.
My code do a zoom, but I need center de pega zoomed in the tapped position, this not work in my code.
Do you recommend I change the view I'm using?
Double tap Zoom 10 years 3 months ago #10492
try to add this method to PDFLayoutView:
public PDFLayout getLayout(){
return m_layout;
then change your code with something like that
PDFLayout layout = m_view.getLayout();
PDFLayout.PDFPos pdfPos= layout.vGetPos((int) x, (int) y);
If it doesn't work, check x and y values...are they correctly passed to your method?
