PDFThumbListener do not work with fragment 10 years 3 months ago #10519
  • saynas
  • saynas's Avatar Topic Author
Hello, i have a problem when i use Radaeepdf with fragment, PDFThumbView listener work fine with activity but that do not work with fragment.
Thre is any exemple of using RadaeePdf win Fragment ?
I need Help . Thinks
PDFThumbListener do not work with fragment 10 years 3 months ago #10541
Dear Saynas,
Sorry for the late reply.
Make sure that the fragment is implementing the needed listeners (not the activity), if you are already doing that, Can you please share your code so we can check it.
Note: If you are using fragment because you need to use a pager, you can check our pager example (com.radaee.reader.PDFPagerAct) in the RDPDFReader module.
