Checkboxes not being marked 10 years 2 months ago #10566
  • fdelcaz
  • fdelcaz's Avatar Topic Author
Hi:
I have recently upgraded my license to premium. I´m trying to edit different documents and i have found that checkboxes are not working properly. They arent being highlighted or displaying the typical check mark when touched. I have also noticed that m_annot.GetEditType() returns -1.. What do I have to do?
Checkboxes not being marked 10 years 2 months ago #10567
to perform the check mark you have to tap the checkbox and then tap the "Do button".
This button calls the onAct() method of PDFReaderAct that calls PDFPerformAnnot() that makes the tick.
The m_annot.GetEditType() correctly returns -1 because this annotation is not text-box, you should use m_annot.GetType().
For more info check this : www.radaeepdf.com/documentation/javadocs...ation.html#GetType--
The following user(s) said Thank You: fdelcaz
Checkboxes not being marked 10 years 2 months ago #10569
  • fdelcaz
Thanks. I´ve tried with getType() and it returns 20. I need the checkboxes to be marked automatically,, without tapping anything but the checkbox. Is this possible?
Checkboxes not being marked 10 years 2 months ago #10570
yes, you can move the code from PDFPerformAnnot (PDFReader.java) to the OnClick listener or where you want.
Something like that :
int check = m_annot.GetCheckStatus();
		if( m_doc.CanSave() && check >= 0 )
			switch( check )
			case 0:
				m_annot.SetCheckValue(true);
				break;
			case 1:
				m_annot.SetCheckValue(false);
				break;
			case 2:
			case 3:
				m_annot.SetRadio();
				break;
			m_view.vRenderSync(m_annot_page);
			if( m_listener != null )
				m_listener.OnPageModified(m_annot_page.GetPageNo());
PDFEndAnnot();
