PDFThumbView problem with landscape PDF 10 years 2 months ago #10579
  • jorisk
  • jorisk's Avatar Topic Author
When I display the thumbs of a landscape PDF, the display of this one is really weird, like "pixelised".
There is the same problem when the first page of the PDF is showed in the tree view before opening it.
It is not coming from my PDF because the problem appears with every landscape PDF I have.
I tried with the 3.6.2RC2 version, same problem.
Can you tell me what to do to resolve this?
Last edit: by jorisk.
PDFThumbView problem with landscape PDF 10 years 2 months ago #10580
I think your file contains pre-rendered thumbs.
You should remove them from the file.
Doing that RadaeePDF engine will render each thumbnail at higher resolution.
If you've some doubt about that, may you upload your pdf file here?
We will check it.
The following user(s) said Thank You: jorisk
PDFThumbView problem with landscape PDF 10 years 2 months ago #10581
  • jorisk
Thanks for your fast answer. Here is the document.
PDFThumbView problem with landscape PDF 10 years 2 months ago #10582
  • jorisk
That was the problem, it is resolved now! Thank you!
PDFThumbView problem with landscape PDF 10 years 2 months ago #10593
  • jorisk
Is it possible to ignore the PDF pre-rendered thumbs and use the normal RadaeePDF engine to render each thumbnail at higher resolution?
PDFThumbView problem with landscape PDF 10 years 2 months ago #10602
at the moment there are no direct APIs to achieve this.
We will evaluate it but we can't promise that it will be implemented soon.
