Font not rendered (embedded) 10 years 2 months ago #10596
  • apait
  • apait's Avatar Topic Author
I've got problems with the attached pdf: some of the fonts aren't rendered at all, but they seem to be all embedded.
I tried not only with our application, but also with your reader-demo.
Any thoughts? Could there be something wrong with the pdf?
lukasmueller.at/AndroidNormal_PDF_1.pdf
thanks,
lukas
Font not rendered (embedded) 10 years 2 months ago #10597
I've forwarded the file to dev team.
I'll update you soon.
Font not rendered (embedded) 10 years 2 months ago #10604
  • apait
Any news? It's kind of urgent.
Font not rendered (embedded) 10 years 2 months ago #10605
We're still working on it.
The file has corrupted cmap inside it.
We've found ezPDF, Foxit reader and Foxit rendering engine, PDF.js, MS Edge, MS PDF Viewer from Windows 10 can't display the file properly.
Actually only PDFTron and Acrobat seems to be able to render the document.
May you check your document production flow or rendering engine?
Font not rendered (embedded) 10 years 2 months ago #10606
To provide you full information about document status, here the report from actual veraPDF compliance checker from PDF/A Association.
While scanning your file errors like that below are really frequent:
Could not read embedded TTF for font MSEYYA+VectoraLT-Light
Full report:
File Attachment:
File Name: htmlReport.html.zip
File Size:16 KB
Last edit: by support.
Font not rendered (embedded) 10 years 2 months ago #10607
That's from Ghostscript check:
**** Warning: Embedded TT font lacks required cmap table. Using identity cmap.
   **** This file had errors that were repaired or ignored.
   **** The file was produced by:
   **** >>>> APA-PdfEngine 1.0 <<<<
   **** Please notify the author of the software that produced this
   **** file that it does not conform to Adobe's published PDF
   **** specification.
