Font not rendered (embedded) 10 years 2 months ago #10608
  • apait
  • apait's Avatar Topic Author
ok, thank you for analyzing this.
we will look into the pdf-production-cycle.
Font not rendered (embedded) 10 years 2 months ago #10609
We're doing the same on our rendering side.
Font not rendered (embedded) 10 years 1 month ago #10666
  • apait
We looked into the pdf-production-cycle and also analyzed the PDF files. But we couldn’t find any problems. Our customer uses Asura for quality checks and optimization of the PDF files.
Also we don’t have any problems in iOS (using a different Library).
Maybe there is something special with these PDF files. But could you also check if there is a problem with your Library?
Font not rendered (embedded) 10 years 1 month ago #10667
Hi.
please check it with the last version of the library here : www.radaeepdf.com/download/download-andr...e/56-radaeepdf-3-6-2
This is the change log :
- FIX freetype bugs when loading "post" table, and load correct glyph using char name.
The font that uses the document does not include a cmap by unicode but by name. This definition mode of rendering tables is rare and has highlighted a problem in the FreeType version that we use.
Two weeks ago, I sent you the beta release that fixes the issue via ticket, some days ago we have published it as stable release.
Last edit: by Davide. Reason: more details
