How to disable view scrolling?
10 years 3 weeks ago
#10832
Semenovich
New Member
I want a possibility to disable a PDFView scrolling, but leave a possibility to zoom in(out) the view. Is it possible?
#10837
Davide
User is blocked
Thank you received: 65
if you mean to stop the navigation when the pdf is zoommed, please check this :
www.radaeepdf.com/support/knowledge-base...component&kbartid=15
If not, can you please better explain what you need?
Unable to fill pdf form
