PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11051
  • yuaner
  • yuaner's Avatar Topic Author
We're using the newest library PDFViewer3.8beta4 and it crushes when doing like below:
  1. tap [ViewPager] button
  2. tap back key immediately
The sample application almost 100% crushes.
Here is the crush log.
08-23 19:53:40.198 2955-2955/com.radaee.reader D/AndroidRuntime: Shutting down VM
08-23 19:53:40.199 2955-2955/com.radaee.reader E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.radaee.reader, PID: 2955
java.lang.NullPointerException: Attempt to invoke virtual method 'void com.radaee.view.PDFPageView.invalidate()' on a null object reference
at com.radaee.view.PDFViewPager$1.handleMessage(PDFViewPager.java:53)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5254)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:903)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:698)
And, there is another problem when use PDF file below:
www.heidelberg-mobil.com/fileadmin/hd_mo.../material-design.pdf
  1. Show the file in ViewPager.
  2. Swap several pages very quickly.
  3. Press back key immediately.
It will back to MainActivity, but UI is blocked several seconds until CRUSH!!
The crush log is the same as above.
Hope will be fixed soon. Thank you.
Last edit: by yuaner.
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11052
this issue has already been fixed.
Please try with the latest beta version : www.radaeepdf.com/download/download-prev...ile/61-radaeepdf-38b
About the second issue, there is no attachment, can you please send us the pdf?
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11053
  • yuaner
Thank you about the first one.
I'm sorry about the second one. I don't know why the attachment upload failed. Maybe too large.
Would you try the url below?
www.google.com/#newwindow=1&q=material-design.pdf
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11054
sorry the link is not working.
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11055
  • yuaner
Sorry,try this link please.
blog.chengyunfeng.com/design/material-design.pdf
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11063
now the link works properly.
I have checked you pdf with the last version o the library and there is no issue.
Please try it with the last beta and let us know if it's ok for you.
