PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11068
  • yuaner
  • yuaner's Avatar Topic Author
I checked the last version of the library, the crush issue is fixed.
But UI blocked issue is still not fixed.
Notice these points please:
  1. Swap QUICKLY. (Don't wait the content be shown.)
  2. Tap back key QUICKLY. (Don't wait the content be shown.)
  3. Check MainActivity's UI response immediately after it shown. (It will response again after several seconds.)
It's almost 100% happens. Would you check about it again.
Thank you.
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11070
we have done some deeper tests on it, when you tap back the ViewPager is still processing the render, then it stops all to prevent memory leaks.
So the few seconds are necessary to prevent the crash and the steps to reproduce it aren't normal behaviour.
PDFViewer3.8beta4 ViewPager crush issue 9 years 11 months ago #11073
  • yuaner
Thank you.
So the UI not response issue won't be fixed in near future, right?
