paperclips turn 9 years 11 months ago #11065
  • Viachaslau
  • Viachaslau's Avatar Topic Author
Hi! We have a small problem. When we use landscape orientation pdf - clip inverted. Portrait orientation pdf - normal.
The code in your project.
Project PDFReader. Class PDFReader.java. Method onTouchNote(MotionEvent event):
private boolean onTouchNote(MotionEvent event) {
if (m_status == STA_NOTE) {
switch (event.getActionMasked()) {
case MotionEvent.ACTION_UP:
PDFPos pos = m_view.vGetPos((int) event.getX(), (int) event.getY());
PDFVPage vpage = m_view.vGetPage(pos.pageno);
Page page = vpage.GetPage();
if (page != null) {
//float pt[] = new float[2];
//pt[0] = pos.x;
//pt[1] = pos.y;
//page.AddAnnotText(pt);
~~~~~~~~~~~~~add this code~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
float pt1[] = new float[4];
pt1[0] = pos.x;
pt1[1] = pos.y;
pt1[2] = pt1[0] + 20;
pt1[3] = pt1[1] + 25;
page.AddAnnotAttachment("/storage/emulated/0/Download/myPDF.pdf", 2, pt1);
m_view.vRenderSync(vpage);
if (m_listener != null)
m_listener.OnPageModified(vpage.GetPageNo());
break;
return true;
return false;
Can we somehow affect this?
paperclips turn 9 years 11 months ago #11066
  • Viachaslau
paperclips turn 9 years 10 months ago #11084
can you reproduce the issue with all the annotation types?
Can you reproduce the issue with all your pdfs? Can you please send us one of these?
I think that the problem is related to the orientation of the pdf itself.
paperclips turn 9 years 10 months ago #11089
  • Viachaslau
Hi. Yes. This problem is related to the orientation of the pdf itself.
The only problem with attached annotations. Text annotation is good.
www.dropbox.com/s/rtq3azivs6lprq4/12345.zip?dl=0
> pdf files
Last edit: by Viachaslau.
paperclips turn 9 years 8 months ago #11395
sorry for the late reply.
We have sent the issue to our developers and we'll get back to you as soon as possible.
paperclips turn 9 years 8 months ago #11399
we have just published a new 3.9RC1 version of the library that solves the issue.
You can download it here : www.radaeepdf.com/download/download-andr...ile/64-radaeepdf-3-9
The following user(s) said Thank You: Viachaslau
