How to add margin/padding between pages 9 years 10 months ago #11232
  • moontech
  • moontech's Avatar Topic Author
I want to add more margin between all pages in PDF viewer.
How i can achieve this functionality ?
How to add margin/padding between pages 9 years 10 months ago #11233
You can achieve this by setting the page gap.
PDFView.vSetPageGap
PDFLayout.vSetPageGap
How to add margin/padding between pages 9 years 9 months ago #11280
  • moontech
PDFView.vSetPageGap
There method setGap around pages.
We need to set Get for Top and bottom gaps so we can differentiate pages.
How we can achieve this ?
How to add margin/padding between pages 9 years 9 months ago #11286
  • moontech
any reply for me ?
How to add margin/padding between pages 9 years 9 months ago #11288
The page gap is handled based on the view mode, i.e. in case of vertical mode the gap will be used vertically between pages (top and bottom).
in case of horizontal mode the gap will be used horizontally between pages (left and right).
So if you need something different than that, you need to change the behavior of the method vLayout of the view mode you are using.
