SaveAs method always returns False. 9 years 6 months ago #11246
  • sbettal
  • sbettal's Avatar Topic Author
public boolean SaveAs(String path, boolean rem_sec) {
return saveAs(hand_val, path, rem_sec);
The above method of Document class always returns false. So i am unable to save the pdf to new location. I stuck here.
SaveAs method always returns False. 9 years 6 months ago #11247
Some check:
- are you activating a Premium license?
- are you using an absolute path?
- are you sure the destination path writable?
May you show the code you're using?
SaveAs method always returns False. 9 years 6 months ago #11248
  • sbettal
Yes activated Premium license.
yes using absolute path. And the same code is working fine in other build.
public boolean pdfSaveAs(String path) {
return m_doc.SaveAs(path, true);
And destination path is writable.
SaveAs method always returns False. 9 years 6 months ago #11249
Are you running it on a 6.0 environment/device?
Have you provided full writing grant using 6.x style permissions?
SaveAs method always returns False. 9 years 6 months ago #11250
  • sbettal
Yes and i have given permission write and read.
SaveAs method always returns False. 9 years 6 months ago #11251
Are you asking for permission within the code like developer.android.com/training/permissions/requesting.html.
And may you confirm: are you on Android 6.x+?
Sorry if I insist, I'm trying to retrive as much information as possible.
