Global.init() - how come Activity and not Context? 9 years 9 months ago #11340
  • RickB
  • RickB's Avatar Topic Author
I'm looking at your library and I see the Global.init() function requires an Activity as the first parameter. This is a bit confusing as I wonder if I have to call the init() function on each activity?
I checked the code and it looks like it doesn't need an Activity at all - just the Context. I'd prefer to call the init() from my Application class as I use the library to read PDFs before they're even shown (so before the Activity class would call the init() function.
It looks like I could just modify the ViewLib code myself, but since that will break on an update, is this simple change something you could do?
Thanks!
Last edit: by RickB. Reason: typo
Global.init() - how come Activity and not Context? 9 years 9 months ago #11341
we have sent your post to our developers, they will check it and get back to you as soon as possible.
Global.init() - how come Activity and not Context? 9 years 9 months ago #11368
Dear Rick,
A new beta version 3.8.1beta2 has been published.
Global.Init accepts Context object as parameter but the Context object must be derived from ContextWrapper, otherwise it may cause a crash in the native part that is using ContextWrapper, because Context.getPackageName() is abstract method, without implementation
The following user(s) said Thank You: RickB
Global.init() - how come Activity and not Context? 9 years 9 months ago #11370
  • RickB
Thanks Nermeen!
I appreciate both Radaee's willingness to consider improvements and your quick response! I will try this out once I have the other PDF stuff on my plate finished.
-Rick
