Making PDF and MERGE 9 years 1 month ago #11601
  • 부길김
  • 부길김's Avatar Topic Author
i found a method of merging two pdf.
(www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=67)
However, I want to take a few pages from one pdf file to make a new pdf.
is it possible?
and another question:
1. make a 2 pdf (blank PDFDocument class and PDFDocument Class loaded with real PDF file)
2. and Add PDFDocument Class loaded with real PDF file to Blank PDFDocument class
is it possible way?
Making PDF and MERGE 9 years 1 month ago #11603
The article example is for windows version, for Android you can check PDFTestAct in RDPDFReader module.
Yes:
  • it's possible to take a few pages from one pdf file to make a new pdf.
  • it's possible to make a 2 pdf (blank PDFDocument class and PDFDocument Class loaded with real PDF file).
  • it's possible to Add PDFDocument Class loaded with real PDF file to Blank PDFDocument class
All your requests can be achieved by manipulating the part that opens and loops over the documents.
Making PDF and MERGE 9 years 1 month ago #11604
  • 부길김
you mean i have to see PDFTestAct.java ? is that all?
and m_doc.ImportPage() and RemovePage() is only operate when buy premium license. but i have to test before buy it.
Is there any way?
Making PDF and MERGE 9 years 1 month ago #11605
I was indicating PDFTestAct.java because your post is under Android development and the article referes to Windows development.
For Android, PDFTestAct.java has an example of concatinating pdfs (concat_pdf()).
Yes, these features require the premium license, but you can test them using either the demo project (which is activated with a premium license) or your project but you need to give it the demo project's package name..
For details, check www.radaeepdf.com/support/knowledge-base...=component&kbartid=4
Making PDF and MERGE 9 years 1 month ago #11606
  • 부길김
in my project looks likt it.
public class Global
public static int mLicenseType = 2;
public static String mCompany = "radaee";
public static String mEmail = "This email address is being protected from spambots. You need JavaScript enabled to view it.";
public static String mKey = "LNJFDN-C89QFX-9ZOU9E-OQ31K2-FADG6Z-XEBCAO";
public static void Init(Activity act)
//second para is license type
// 0 means standard license.
// 1 means professional license
// 2 means premium license
//3rd para is company name string(not package name)
//4th para is mail
//5th para is key string
//the package name got by native C/C++ library, not by pass parameter.
Init( act, mLicenseType, mCompany, mEmail, mKey);
is this possilble to test premiem license function?
Making PDF and MERGE 9 years 1 month ago #11607
Yes, but make sure that the package name is "com.radaee.reader" for the license to work.
