How to use handwriting class? 9 years 7 months ago #11614
  • eastxing
  • eastxing's Avatar Topic Author
I found a file called HWriting.java, from the comments I think this is the functionality my customer wanted.
But I do not know how to use it, can you show me some example codes, thanks.
How to use handwriting class? 9 years 7 months ago #11615
HWriting is now deprecated, You can use Ink class instead (Ink annotation),
For more details, check PDFLayoutView.
How to use handwriting class? 9 years 7 months ago #11616
  • eastxing
I have used Ink class already.
What I want is "variable point size based on velocity", just like this project provided github.com/gcacace/android-signaturepad , do you have plan to implement this feature?
How to use handwriting class? 9 years 7 months ago #11617
We're evaluating it but not yet planned the development.
The integration between PDF annotations and the project you was linking from GitHub would need a Canvas -> SVG -> PDF integration.
The same should be portable to iOS.
That means it'd take months before we would release a public release.
We will update you as soon as possible.
Last edit: by support.
