Search not working in android native sdk 9 years 6 months ago #11708
  • raghul.sivarajan
  • raghul.sivarajan's Avatar Topic Author
I have used the sample application comes with the sdk in which the search is working fine. I am making a POC so I tried integrating Radaee pdf with my POC application. The search functionality is not working now. It always shows a toast message like "no more found". Is this a licensing issue? kindly clarify on this
Search not working in android native sdk 9 years 6 months ago #11709
It seems you're not activating the license.
I suspect your app has an application package name different from our demo project.
www.radaeepdf.com/support/knowledge-base...=component&kbartid=4
Without license activation, text search and extraction shall return false.
The following user(s) said Thank You: raghul.sivarajan
