How to integrate your sdk in to my project? 9 years 6 months ago #11730
  • rachnasagar
I want to integrate your RDPDF reader with viewlib in my project?
I have started to integrate but it give certain errors.
File Attachment:
File Name: Errorlog.txt
File Size:2 KB
How to integrate your sdk in to my project? 9 years 6 months ago #11732
it seems that you missed to copy the native library "librdpdf.so" to your own project.
Anyway I suggest you to check this guide : www.radaeepdf.com/support/knowledge-base...component&kbartid=41
How to integrate your sdk in to my project? 9 years 6 months ago #11735
  • rachnasagar
I am using ecilpse so please help me in this ]
01-17 11:22:04.350: E/AndroidRuntime(7953): Caused by: java.lang.ClassNotFoundException: Didn't find class "com.radaee.reader.PDFNavAct" on path: DexPathListzip file "/data/app/com.rachnasagar-1/base.apk"],nativeLibraryDirectories=[/vendor/lib, /system/lib
getting this error and when I am adding your library it shows error
How to integrate your sdk in to my project? 9 years 6 months ago #11737
  • rachnasagar
I have done it. pdf is opening but nothing play in that pdf like highlighter,underline,nor videos not weblink.
only this message is showing "can't write or encrypted!"
How to integrate your sdk in to my project? 9 years 6 months ago #11738
that's because you don't have a license, if you want to try the library in your own project with all the features, you have to follow this guide : www.radaeepdf.com/support/knowledge-base...=component&kbartid=4
