How to give path of sdcard in PDFSetRootPath? 9 years 3 months ago #12190
  • rachnasagar
I want to give path of sdcard PDFSetRootPath from where I read files?
presently I am passing this for internal memory m_grid.PDFSetRootPath("/mnt/sdcard);
but if I have to pass this for sdcard what I have to do ?
How to give path of sdcard in PDFSetRootPath? 9 years 3 months ago #12192
this is not related to the library, but I suggest you to use Android standard method
Environment.getExternalStorageDirectory().getAbsolutePath()
If it doesn't fit you, you can check others Android methods.
How to give path of sdcard in PDFSetRootPath? 9 years 3 months ago #12193
  • rachnasagar
I checked all these methods but actually its not working
How to give path of sdcard in PDFSetRootPath? 9 years 3 months ago #12195
even if this is not related to the Radaee library I suggest you to read and check this thread : stackoverflow.com/questions/5694933/find...nal-sd-card-location
