Setting Blend Mode when drawing a ResImage 9 years 3 months ago #12296
  • AnypadDev
  • AnypadDev's Avatar Topic Author
Hi, Is there a way to set the blend mode when drawing a ResImage onto a PageContent?
i.e. pageContent.DrawImage(resImage);
Setting Blend Mode when drawing a ResImage 9 years 3 months ago #12298
Unfortunately, this feature is not supported.
And it's not currently planned.
Setting Blend Mode when drawing a ResImage 9 years 2 months ago #12347
Please check the new version 3.13 , it has a new method:
GState.SetBlendMode()
 * set blend mode to graphic state.
 * @param bmode 2:Multipy<br/>
 *              3:Screen<br/>
 *              4:Overlay<br/>
 *              5:Darken<br/>
 *              6:Lighten<br/>
 *              7:ColorDodge<br/>
 *              8:ColorBurn<br/>
 *              9:Difference<br/>
 *              10:Exclusion<br/>
 *              11:Hue<br/>
 *              12:Saturation<br/>
 *              13:Color<br/>
 *              14:Luminosity<br/>
 *              others:Normal
 * @return true or false.
For example, check PDFTestAct.NewPage in RDPDFReader module
The following user(s) said Thank You: AnypadDev
