Customize toolbar 9 years 2 months ago #12392
  • iosDeveloper
  • iosDeveloper's Avatar Topic Author
Could you please help me to understand how I can customize the toolbar? I need to remove some default icons and actions that will not be used, and add some custom buttons to it.
I believe this should be easily done, but I don't see any guides or examples that would help me to do it.
Thanks in advance!
Customize toolbar 9 years 2 months ago #12397
To apply modifications to the toolbar, you need to modify the following:
  • com.radaee.reader.PDFViewController
  • layout files like: bar_act, bar_cmd, bar_find, bar_annot and pop_view
