Accessing existing bookmark through Radaee 8 years 9 months ago #12976
  • openbee.dev
  • openbee.dev's Avatar Topic Author
We would like to add new functionnality to our app for both Android and iOS version, which allow user to view all the bookmarks of the pdf on a panel.
Bookmarks already exist (you can view it with Acrobat Reader DC for example), so the purpose is not to add bookmarks, just read it.
However, we did not find a way to do so.
Can you help us by describing the process flow?
We are using Radaee v3.4 (Android) and v3.8 (iOS).
Attached to this you can find a PDF which already has bookmarks.
Thank you for your help
Last edit: by openbee.dev. Reason: attachment
Accessing existing bookmark through Radaee 8 years 9 months ago #12979
This type of bookmarks is already available as outlines (via the outlines button in the demo project).
For Android: please check com.radaee.util.CommonUtil.showPDFOutlines
For iOS: please check viewMenu in RDPDFViewController
Note, you are using a very old version of Android 3.4, we recommend that you update to the latest version 3.14.3
The following user(s) said Thank You: openbee.dev
