Add annotate text to pdfview is not working 8 years 6 months ago #13346
  • mobileapps@dewa.gov.ae
  • mobileapps@dewa.gov.ae's Avatar Topic Author
I need to add text string to the pdflayout to a position (using rect).
I tried different ways to add string to the view but its not working. I can add images to a particular position using bitmap and positions (rect). The same way am trying to add the text string. Is there any option to resolve my issue?
Thanks in advance.
Add annotate text to pdfview is not working 8 years 6 months ago #13347
if you want to add text to the pdf structure, I suggest you to look at this: www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=35
If you want to add text like an edit text annotation, you should follow this article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=43
Add annotate text to pdfview is not working 8 years 6 months ago #13348
Thanks for your reply.
I need the add text to pdf structure and you suggested one option, but which required the premium license. I don't have the premium license but I have professional license. How can i do the same with professional license.
Thanks...
Add annotate text to pdfview is not working 8 years 6 months ago #13349
you need a premium license to use these methods, with a professional license you can add text as annotation.
You can upgrade your license to a premium to use these methods.
If you want to try premium features before buying the license, I suggest you to follow this article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=4
