PDF Forms not showing inputted data 8 years 6 months ago #13355
  • pooja
  • pooja's Avatar Topic Author
PDF Forms not showing inputted data. Currently, when user inputs data into PDF form, it only shows square characters instead of the inputted data. Please see attached screenshots
Tablet:
-Ellipsis 10 (QTAIR7)
-Android version 5.1
Pooja
PDF Forms not showing inputted data 8 years 6 months ago #13356
  • pooja
One more pdf with same problem is attached below.
Android 5.0.2
Device model number - SM-T800
Last edit: by pooja.
PDF Forms not showing inputted data 8 years 6 months ago #13358
did you try to follow this article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=25 ?
Check it and let us know..
PDF Forms not showing inputted data 8 years 6 months ago #13360
  • pooja
Yes, I tried that but it still doesn't show the data. Could you please suggest
Pooja
PDF Forms not showing inputted data 8 years 6 months ago #13363
you have a not embedded font (helvetica) in your pdf, so try to change annot font.
I suggest you to edit Global class ad follow :
Replace :
if (!setAnnotFont("DroidSansFallback") && !setAnnotFont("Arimo") && face_name != null) {
            setAnnotFont(face_name);
with :
if (!setAnnotFont("Arimo") && !setAnnotFont("DroidSansFallback") && face_name != null) {
PDF Forms not showing inputted data 8 years 6 months ago #13367
  • pooja
Hi David,
After making these changes, only text from one field is getting displayed. Other fields, still show garbage characters. Could you please suggest something for this?
Pooja
