Problem with editable fields 8 years 6 months ago #13366
  • вламих
  • вламих's Avatar Topic Author
I added ViewLib into my project, project has package="com.radaee.reader", edit functionality enabled.
Now i have problems with editable fields (monosnap.com/file/NUjlTOyJb6Hu7bCDU4IzEiHZyuPzxT#).
In demo app keyboard appears when i tap editable area, but in my app - no.
Problem with editable fields 8 years 6 months ago #13369
if you can't reproduce it with the demo project, it's something related to your own project.
I suggest you to check this article to build your first app using Radaee library www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=41
Problem with editable fields 8 years 6 months ago #13376
  • вламих
We tried to create a simple application from scratch, but it also doesn't work.
PDF file attached, there is a project (drive.google.com/open?id=1itzXRXxpN_QDlBIxbhyAGgBuU71VBPpn)
This issue blocks us from going forward and purchase your product.
Last edit: by вламих.
Problem with editable fields 8 years 6 months ago #13377
You did not add the activity that handles fields editing in the manifest.
Please add the following:
<activity
            android:name="com.radaee.util.PopupEditAct"
            android:theme="@android:style/Theme.Translucent"
            android:configChanges="orientation|keyboardHidden|screenSize">
 </activity>
