background-Color during caching 8 years 5 months ago #13494
  • apait
  • apait's Avatar Topic Author
I just upgraded to v3.15.
Before that i could change the background-color during rendering-mode to transparent. I did this in VCache
final protected void vDraw(BMP bmp, int x, int y)
		if( m_render && m_dib != null )
			m_dib.DrawToBmp(bmp, x, y);
		else
			bmp.DrawRect(Global.backgroundColorForCache, x, y, m_w, m_h, 1);
That's not working anymore. Could you tell me what you changed and how I could achieve this again?
Lukas
background-Color during caching 8 years 5 months ago #13495
  • apait
okay. found it myself 10 minutes after posting...
In VThread there is a new method Draw where you could set your color
ms_paint.setColor(Global.backgroundColorForCache);
