duplicate entry: com/radaee/view/PDFLayout$1.class 8 years 4 months ago #13605
  • андчер
  • андчер's Avatar Topic Author
Hi
I updated it to version 3.15 and added a view from the archive wrap3.14c.zip. Why does this error occur?
Error:Execution failed for task ':app:transformClassesWithJarMergingForDebug'.
> com.android.build.api.transform.TransformException: java.util.zip.ZipException: duplicate entry: com/radaee/view/PDFLayout$1.class
duplicate entry: com/radaee/view/PDFLayout$1.class 8 years 4 months ago #13606
I suggest you to check this article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=2
If you are using a 3.15 version, download and include wrap3.15, otherwise using different versions may cause problems.
duplicate entry: com/radaee/view/PDFLayout$1.class 8 years 4 months ago #13619
  • cmahoney52
  • cmahoney52's Avatar
  • Thank you received: 2
Also for the later versions, make sure you delete the old .jar file that was included in the lib folder, otherwise you'll also occasionally see this issue as the .jar and the raw file both might define PDFLayout.class
