Find text using PDFLayoutView 8 years 4 months ago #13634
  • Kin Chung
  • Kin Chung's Avatar Topic Author
I tried to use PDFLayoutView to search text in the PDF using PDFFindStart() and PDFFind(), and it works properly and highlighted the matches.
However, is there any way to.....
1. obtain the search results programatically?
2. search the entire document, instead of just searching the next occurance and stops? (probably obtaining an array of search results)
Any help is appreicated.
Find text using PDFLayoutView 8 years 4 months ago #13636
here you will find how to search text in the whole pdf programmatically : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=123
