PDF JPEG rendering quality issue 8 years 2 months ago #13850
  • thetlynnhan@gmail.com
  • thetlynnhan@gmail.com's Avatar Topic Author
I am currently using Radaee Android SDK (Android Studio Version 3.7 Beta1) and I have noticed that PDF JPEG quality becomes lower than original quality (pixelated text and edges) when viewing through the Android SDK reader. I tried to open the same PDF with Radaee PDF Viewer app (downloaded from Playstore) and found that quality is much better (smooth text and edges).
We have set the rendering quality to 'Best' in our codes but there was no changes with the quality. Any advice on improving the image quality will be most appreciated.
Ricky
PDF JPEG rendering quality issue 8 years 2 months ago #13851
Dear Ricky,
We recommend that you update to the latest version , this may solve your issue.
If not, please send us a sample pdf.
