Required Fields 8 years 1 month ago #13896
  • markanson
  • markanson's Avatar Topic Author
Hi! I'm from ServiceTitan!
Is there any way to make a field required before being able to save the document?
Last edit: by markanson.
Required Fields 8 years 1 month ago #13903
you can check if a field is required with the following method :
         * get annotation field flag in acroForm.<br/>
         * this method require premium license
         * @return flag&1 : read-only<br/>
         * flag&2 : is required<br/>
         * flag&4 : no export.
        final public int GetFieldFlag()
            return Page.getAnnotFieldFlag(page.hand, hand);
The set method is not supported.
Required Fields 8 years 1 month ago #13909
  • markanson
Thank you Davide,
We're not looking to check if a field is required, we're looking to make it so that a field that is set up as required (in acrobat for example) also has that same requirement respected by Radaee PDF.
Our goal is that our users are not able to save a pdf without having entered something into that required field.
Required Fields 8 years 1 month ago #13912
if a filed is flaged as required with Acrobat you can read the status using GetFieldFlag(), but you can't set required flag using radaee SDK.
You can check the status of the annots with required flag (whether is filled by the user or not) before saving the document.
