How to use hyperlinks 7 years 10 months ago #14092
  • radaee's Avatar Topic Author
if you are developing on android, there is a listener with callback method:
OnPDFAnnotTapped();
it implement on high level(PDFViewController class in Demo project).
in this method you can call m_view.PDFPerformAnnot(), this call will return callback:
OnPDFOpenURI();
this callback tells uri address user tapped.
and you can set customer uri on PDF Editor for some customer operation.
How to use hyperlinks 7 years 10 months ago #14098
You shall interact with document contents after a single or double tap:
In pseudo-code you shall:
i=ObjsGetCharIndex(tap_x, tap_y)
start=ObjsAlignWord(i, -1)
end=ObjsAlignWord(i, 1)
string=ObjsGetString(start,end)
Then you should apply a regex to string and evaluate if it's a proper URI syntax.
How to use hyperlinks 7 years 10 months ago #14100
You shall add pagee.ObjsStart();
just after Page pagee = m_doc.GetPage(0);
How to use hyperlinks 7 years 10 months ago #14108
I've a doubt about x, y in your code.
Which is the value you're loading in the variables?
Are you losing touch coordinates, isn't it?
How to use hyperlinks 7 years 10 months ago #14110
i tested following codes, and it works:
m_annot_pos = m_layout.vGetPos((int) event.getX(), (int) event.getY());
m_annot_page = m_layout.vGetPage(m_annot_pos.pageno);
Page page = m_doc.GetPage(m_annot_page.GetPageNo());
page.ObjsStart();
int ichar = page.ObjsGetCharIndex(new float[]{m_annot_pos.x, m_annot_pos.y});
int start = page.ObjsAlignWord(ichar, -1);
int end = page.ObjsAlignWord(ichar, 1);
String result = page.ObjsGetString(start, end);
Log.e("TAP", result + " " + ichar + " " + start + " " + end);
if not work yet. it maybe following issue:
1.you have not active any license, even demo license.
2.the PDF page is pure image page, the text is pixel image, not fonts.
How to use hyperlinks 7 years 10 months ago #14112
if red watermark displayed on page, it mean, you have not actived demo license.
this mostly because you have changed package name.
if blue watermark displayed, i think your PDF file is pure image page.
the attachment is the PDF file i test, acturally, it works on every PDF file.
The following user(s) said Thank You: Evalarm
