PDF not rendering correctly 7 years 9 months ago #14141
  • apait
  • apait's Avatar Topic Author
two months ago my colleague (xxxxxxxxxxxxxxx) opened a bug-ticket, that a certain pdf is not rendering correctly (attachements: pdf and screenshot of incorrect rendering (black rectangle)).
Your support told him, that you fixed the issue and gave a version with the fix to him (I don't know if he checked your version then and he is not available anymore).
I updated our project now to 3.15.3 and the issue is still present.
I tested with your 3.15.3 Sample and even with the 4.0beta Sample, issue still present.
As we thought the issue is resolved, we planned on rolling out the fix this week. Can you take a quick look? Did something not transfer to production code?
Best regards,
Lukas Hollmann
Last edit: by support. Reason: Removed email address from public forum.
PDF not rendering correctly 7 years 9 months ago #14142
  • apait
Last edit: by apait.
PDF not rendering correctly 7 years 9 months ago #14143
Dear user, I was moderating your post: better not to publish private email address on a public forum.
I'll get in touch with you on the trouble ticket platform: it seems that no one from your side was confirming it and the fix (which was a workaround because of some bad encoded PDF never go into production).
I'll ask my colleagues to check.
The following user(s) said Thank You: apait
PDF not rendering correctly 7 years 9 months ago #14146
Dear user,
sorry for delay.
We wasn't able to find the old topic you was referring to, sorry again.
By the way: I invite you to open a new support ticket on www.radaeepdf.com/support referring to this post: me or my colleagues will share with you a fixed version of the native libraries.
PDF not rendering correctly 7 years 9 months ago #14151
Even if we've not received any feedback from your side, we applied the fix on last 3.50 RC2.
PDF not rendering correctly 7 years 9 months ago #14152
  • apait
thank you, i will check it out!
just for clarification: you changed your releasenumbers? the 3.5RC2 was treated as 4.0 one or two weeks ago, correct?
