Highlighter color 7 years 9 months ago #14157
  • rishikesh@appristine.in
  • rishikesh@appristine.in's Avatar Topic Author
hello everyone, I buy a license of PDF, I make highlighter color change dynamically.
When I highlight the text and repeatably highlight on same text, then color get darker and darker...
Please, help me it is very important for me.
Early feedback is appreciated.
Highlighter color 7 years 9 months ago #14158
You're simply applying more and more highlight annotations one on the top of the previous one.
Highlighter color 7 years 9 months ago #14159
Exactly, u r right sir but my question is how to replace the old highlight color to new color without make it overlap.
Highlighter color 7 years 9 months ago #14162
it seems you shall modify some codes.
current AddAnnotMarkup implement:
public boolean AddAnnotMarkup( int cindex1, int cindex2, int type )
int color = Global.highlight_color;
if( type == 1 ) color = Global.underline_color;
if( type == 2 ) color = Global.strikeout_color;
if( type == 4 ) color = Global.squiggle_color;
return addAnnotMarkup2( hand, cindex1, cindex2, color, type );
so, you can add a new method:
public boolean AddAnnotMarkup( int cindex1, int cindex2, int type, int color )
this way, you shall add parameter to a new wrapping.
