Minimum zoom factor 6 years 11 months ago #14462
  • cornelius
  • cornelius's Avatar Topic Author
Hi
How do I set the minimum zoom factor on a PDF?
I want to be able to zoom out further than 100%
Minimum zoom factor 6 years 11 months ago #14468
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
Dear user,
Depending on the render mode you are using, you can modify the method vLayout():
after the assignment of m_scale_min, multiply m_scale_min for a positive <1 factor (depending on the level of "zoom-out" you want).
i.e.
m_scale_min *= 0.8;
Minimum zoom factor 6 years 11 months ago #14476
  • cornelius
Thank you for the reply, I however think this is for iOS.
How do I set the minimum zoom factor on Android, because I can't edit the source code of the library
Minimum zoom factor 6 years 11 months ago #14477
  • luca.f
  • luca.f's Avatar
It is for Android.
Could you please check what version you're using, and what type of license?
If it is Professional of Premium, you can download the source code from your panel. If it is one of the more recent versions, source files are included.
When you have access to the source code, you can find the classes to edit in ViewLib\src\main\java\com\radaee\view
